RE: Engine Running problems
Bruce, I removed the high speed needle assembly and put air thru it. It does not seem clogged. I will reassemble and blow into the muffler pressure line and see if I get fuel into the carb. I removed the muffler and cleaned it. The nipple was not stopped up but could my muffler not be pressuring my tank correctly? How would I check that?
