RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 08-12-2007 | 01:33 PM
  #4709
crashcrash
Default RE: E-FLIGHT BLADE CP
ORIGINAL: lettucelord
Hey i have a blade CP, it flew fine for a little while, but now when you add full throttle, it just sits there on the ground until you start to increase the trim, then it puts the pitch in but because of the pitch increase, the engine bogs down and the only way to control it is to pull the throttle out, but then it resets again and wont lift off. I thought it just needed a bit of adjusting so I took it to my hobby shop, and the heli expert sat there for an hour and a half trying to fix it. He replaced a couple bent parts in the rotor head, checked all the servos and everything. He had no idea what was wrong with it. I called Horizon, and the tech guy told me over and over that it had to be the servos, but the thing is, each servo works fine by itself. I want to get this heli going again, so I was wonderin if any of you guys had any suggestions
THanks
Personally, I don't think much of horizon's tech staff...but there's an outside chance he might be right. I'll tell you what I know, maybe it'll help.
* If the tail motor is going (and it don't have to show signs), it could draw power from the main motor reducing lift/speed.
*The main motor it's self may be on the verge of taking a dump
*1 weak servo may also cause this problem. The servo may look like it's working but in fact is defective.
That's one of my major issues with the CP/CPP is that one symtom may be caused by a number of possible problems. Start with the cheapest and work your way up. Tail motor would be high on the list as faras being suspect, the main motor is next, and then servos.
Not only that...it could be two of the above that are happening.
HAVE FUN eh?
