RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 08-12-2007 | 05:07 PM
  #4711
crashcrash
Default RE: E-FLIGHT BLADE CP
ORIGINAL: lettucelord
Haha, thanks for the information. The guy at my hobby store never checked the tail motor, so thanks for suggesting that, I will defiantly check that out. He did check the main motor and servos and thought they were OK, but I will defiantly start replacing things. THanks again
I forgot to mention that the battery may also be the culprit...there's just so many things it could be. Even though a component may check out OK on the bench don't mean it's good and you'll spend a lot of time looking at things that are bad, but you won't see it. Replace things going from cheapest to most expensive until you hit it. It could also be MORE than one thing hurting you also. Man....I think I've seen every possible problem the CP/CPP could develop in the 6 months I owned one.
I bought the E-Sky Honeybee King V2. After converting it to brushless, and fixing the belt throwing problem....I don't work on it, I fly it, day after day, pack after pack...it's VERY dependable.
