RCU Forums - View Single Post - DB SE5a, anyone else?
Old 03-14-2003 | 03:26 PM
Eindecker111
Default DB SE5a, anyone else?
Hi
Cheers guys,that makes sense
Just one other thing,the aileron linkage,as the wings are slightly undercamber,whats the best position for servo linkage,i intend fitting independent servos for each wing,the plan shows a servo outline nothing else,on the top wing,but i think they should be in lower wing,with aileron linkage to top wing.
If thats the case,should servo rod exit above or below bottom wing,with undercamber to wing,do you suggest above,with access hatch to top of wing,or some other way,suggestions please guys!!
Lanc
