RCU Forums - View Single Post - Hobbico Nexstar Float Plane
Old 08-13-2007 | 11:07 AM
jrf
My Feedback: (551)
Default RE: Hobbico Nexstar Float Plane
Adding a sub-fin (ventral fin) will definately help. Add about 50% of the area of the existing fin and rudder. Also check and make sure there is no binding in your ailerons controls.
With that much dihedral, you have a lot of level flight stabiltity that your ailerons have to overcome to make it bank. It's a bit of work, but taking all of the dihedral out of the wing will make it handle MUCH better in the turns.
Jim
