ORIGINAL: knotnuts
No where in my manual is LIPO low voltage circuitry mentioned... It is NO problem to pull a trigger and go back to neutral..... I'm looking for a better animal that's all. I'm sure that there are other ESC's used in electric racing other than the one offered by Aquacraft..... Are all boat friendly ESC's Programmed the same??? I doubt it.
you can just buy a LVC (low voltage cutoff) and still use the stock esc....
and here is the hydra big thunder suggested
http://www.offshoreelectrics.com/pro...d=cas-hydra120
