RCU Forums - View Single Post - 100 degree heat and lean engines
Old 08-13-2007 | 01:34 PM
OzMo's Avatar
OzMo
Default RE: 100 degree heat and lean engines
[&o] well seems a lot of that is going around.
check your fuel system well, make sure your low setting is correct so your not loading it up. then try setting the high end. it will be a fine adjustment. you are right to keep it a little on the rich side. your a better man than i am. i have not braved the 103 degrees we have in the ozarks now.[&:]
