RE: 100 degree heat and lean engines
Do you have a filter in the fuel line between the tank and needle valve? Sounds like it is being starved of fuel when you give it full throttle. A partially pluged filter or some partial obstruction in the fuel line could cause this. Check for dirt in the needle valve also.
