RE: 100 degree heat and lean engines
In hotter weather, you actually need to run the engine at a slightly leaner setting. The warm air is less dense, and probably contains more water. Consequently, less fuel is required. Always follow the mantra of set it to peak, and then richen a couple hundred RPM. The difference for the running engine temperature when its in the air and being properly cooled will be insignificant.
Brad
