RE: Engine blown???
Sounds like the same problem I had, I pulled my sucker until my fingers bleed and it would not start. I checked everything and in teh end it was low compression.
So check your compression if you can turn it easily at the flywheel with your fingers it's dead. And no matter how hard you try it will not start. Sometimes you will get it to fire but only for a split second.
