RCU Forums - View Single Post - ys 110 prop size
Old 08-14-2007 | 10:45 PM
Troy Newman
Default RE: ys 110 prop size
As I said before prop selection has to do with the task you need. So a War Bird Racer is not going to work well ona 5 pitch prop....smaller diameter and Higher pitch will help it.
Back to the question of too much...YEP over 10,000 is too much. Keep it down below 10K
try the 14-14 or the 13-14....
If you want to 3D the model then a good prop is likely the 16-5W...War Bird Racer I say the 13-13 or 14-13, 14-14
Troy Newman
Team YS
