ORIGINAL: hobby_man
ORIGINAL: thestratcat
hey guys, I've got a question concerning li-po's...
am I right in understanding that I can pick up a dual charger (superbrain 977) and say one of the Equinox balance ports (from Tower) and use this to chage packs? what I'm understanding is that I can use the balancer on the pack, then plug it in to charge. I understand that I can use the balancer in conjuction with the charger, but for now, I want to minimize cash out so would like to just get one of the balancer things...
in other news... the Axe CP is coming together slowly, still having problems (either wiring to the rcvr or I read I need a new crystal) with inputs at the trans and movement on the servo's... oh yeah, the MX is flying beautifully... better than a CP ever did...
oh yeah, can I throw the motor/esc combo from my spare MX into the Axe CP? sounds like a pretty decent idea right? will I be overpowering it too bad?
what did you find out about using MX motor nd such in the CP?
I do believe the motor will drop right in, I looked at it last night and it looks good. The only thing holding me back is radio setup... when I push my two sticks are reversed!!! when I push the throttle open, it applies forward cyclic to the heli, use the right stick and push forward, my servo's act like they should when the throttle is moved. I'm not sure on the motor part, I have that disconnected right now.. anyone have any idea what to change? I've went through this one in my mind and am drawing a blank...
