Bump starting is pushing a car in second (first and third might work depending) with the clutch down, as soon as you reach max speed you let go of the clutch untill the engine turns over, then you press the clutch again and play with the throttle untill the engine runs smoothly. It also works in reverse (pushing the car backwards and being in reverse gear). I challenge you to find some buddies and simply push a car untill it starts
