ORIGINAL: []TEX[]
You need to put teh swash mode to 3S if it is not already. I think the default on my 6EXH was 1S, the Axe is 3S.
Secondly, disconnect all the servos and start over.
Pitch and throttle are mixed still have their respective channels 3 and 6. On the front panel of the 6EXH is the list of channels.
It's a simple fix, you just have the channels mixed up. Swap the connectors for channels 2 and 6.
ok, the swash is in 3S, I'll give the swap a try..
I am in mode 2 by the way, but I'm afraid that if I switch that to something else, it may effect my other models, that wouldn't be good.
