RCU Forums - View Single Post - Pull pull cross or not to cross?
Old 08-15-2007 | 10:53 AM
Falcon32's Avatar
Falcon32
Default RE: Pull pull cross or not to cross?
Hi Mike
Thanks for your input here.
I have tried it both ways on a Fliton Extra.
Not crossed; it looks like the cable is going to eat it’s way through a former at the rear of the fuse, but the geometry looks good, the not pulling cable only has a very small amount of slack on it.
Crossed; the cable goes straight from one end to the other, no obstructions perfect, but the not pulling cable gets a lot of slack.
I use a nylon coated cable so no problem if they do touch and I do have one on top and one on the bottom of the servo arm.
I don’t know if it’s worth getting an offset servo arm for this model?
Falcon
