RCU Forums - View Single Post - G-Booster 160 ECU software issue ?
Old 08-15-2007 | 03:21 PM
tahfiet's Avatar
tahfiet
Default RE: G-Booster 160 ECU software issue ?
Hi Stephane!
What's your problem? They are probably delivered with 2.01, that is the latest software I got from Booster. But it might be, that your dealer has an "older" version, or Graupner didn't "FIFO" (first in first out).
It will be just fine. As far as I am aware, the last updates are just for G-80s and other turbines. The thing with the Booster is, that you plug your G-80 to the ECU of your G-160 and just fire it up. The ECU has all the settings for the different turbines onboard and will identify the right engine.
BR,
David
