RCU Forums - View Single Post - HELP! sticks are reversed...
Old 08-15-2007 | 04:42 PM
Heliko's Avatar
Heliko
Default RE: HELP! sticks are reversed...
ORIGINAL: thestratcat
I used the servo map that you gave me yesterday man...
actually it worked until I started the transmitter change, everything was just fine, but since I've introduced the Futaba and the new frequency (still a CP crystal though) I've got the reversed sticks.
I'm almost thinkiing it's programming, but I'm not smart enough to figure it out.
That's just weird. If the Tx is set to mode 2 and the servos are correct then it should work. It really sounds like channels 2 and 3 are reversed. Have you tried switching the connectors on 2 and 3 yet?
