RE: TS2 POST IT HERE...
Dicko, either one of those ratios sounds ok. If you are still running the stock nickel sleeve in the OS, definitely run some Castor. running the nickel sleeve on just synthetic, will lead to the nickel flaking off around the top of the sleeve. I also run Klotz now.
~James
