RCU Forums - View Single Post - Showtime 50.....
Old 08-16-2007 | 02:26 AM
firestone1121
Default RE: Showtime 50.....
ORIGINAL: doubledee
You don't have to take the cowl off each time you fuel if you use 3 lines and a fuel dot. You will have to remove it to mount the fuel dot holder.
Mount the fuel dot holder through the side of the cowl, leave enough length in the fueling line so it can be pulled out through the holder. Once the tank is full, plug the line with the dot and push it back through the holder until the plug is seated in the holder. That is the way I have mine set up.
like this?? works great now! took out the tank, repositioned the vent tube in the tank, and got a dubro kwik-fill fitting. its neat cuz wen you plug the specially designed filler in it stops flow to the carb and bypasses to the tank!! thanks for the help guys! posted my arf pics too
