RCU Forums - View Single Post - Quad Flaps with five (5) channels
Old 02-27-2002 | 01:00 AM
Troy Newman
Default Quad Flaps with five (5) channels
This way you can have flaps and ailerons as separate channels.
I don't think you can get quadflap mixing in that radio....but I do beleive it has flapperon.....so you could get Flap-aileron or flapperon mixing to work......My suggestion would be to hook it up a couple different ways...#1 "y" harness the flaps together and the ailerons together. Then turn on the flapperon mix and see what happens. In this way you might get the best situation
or #2 "y" harness the left side Flap and aileron together then the right side Flap and aileron together then use flapperon and you will get both flap and aileron for the given side moving together and no way for the flap on the right to go up and the aileron on the right to go down.
I think #1 is your best option. Its a trial and erro thing.....Look in your manual for the radio it might have clues.
Troy Newman
Team JR
