RCU Forums - View Single Post - I found another good airplane
Old 08-16-2007 | 11:15 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: I found another good airplane
Yes, but there's one other very important piece of equipment they will need... A brain
Seriously though, to someone with a lot of building/modifying experience, it's a no-brainer, but to someone without that experience, they could easily put the holes in the wrong place, or not think to reinforce the hole area with plywood.
Also, depending on where the holes are placed, the TE might need reinforcing to keep the rubber bands from crushing it.
So yes, it's an easy modification to make (Certainly easier than converting a rubberband wing to bolts) but you still need to know what you're doing.
