Thanks Guys,
My lighting system is a "Curtek" lighting system, sadly they've gone out of business...
I'm having some issues with my port and starboard running lights...
The wires need to be plugged in just like the aileron and flap servo wires, the running light wires keep breaking at the plugs from all the plugging in and un plugging...
I'm trying to setup a system so I can have a small battery velcroed to the wing so I don't need to run the wires back to the fuse...
Looks like I have some soldering to do today...
I also still need to mount the stobe on the tip of the tail...
Sam
Please note:
If you build this plane:
Replace the Nose Strut...
Replace all the Servo connectors, don't use the EZ connectors inc in the kit...
Epoxy both wing halfs together...
Goto 2.5" Du-Bro Wheels...
Remove wheel pants for field or flying off grass...
One more picture:
