ORIGINAL: mowery1
Anybody know of any pic's on here that show choke set-up...That's all I have left before I fire up my DL..Does the electronic ignition module have to be sitting on foam?? Thanks..
Yes and Yes, The module should be mounted to foam and cross tied loose enough to allow some movement (don't crush the foam too much or it will get too much vibration) I just have mine surface mounted with industrial strength velcro from Wal-Mart, it works for me but I'm hesitant to recommend it because the damping may not be as good as foam. I have had just 2 gas engines (SPE 40 and DL50) and mounted both modules this way, both ignition modules have been fine. But as they say "your mileage may vary"
I use a servo on my choke but....
