Help! Almost crashed. Weird problem
I have my antenna routed through fuel line, and then zip tied onto the base loaded antenna. It doesn't touch the frame. The base load is double sided taped on.
I still had the problems. I had all servo wires out the front and to the side, and I had the antenna wire coming out the back and to the other side so as to not cause interference.
Still had the problem.
Used the 3M anti-static bag, problem gone.
Like I said, I know I didn't fix the problem, but at least I can fly (well trying too anyways)
