RCU Forums - View Single Post - Pull pull cross or not to cross?
Old 08-17-2007 | 05:24 AM
Daryl Martel
Default RE: Pull pull cross or not to cross?
You can set it up however you like - the main thing is to avoid a setup that binds, or where 1 line goes excessively slack as it moves towards full travel. Now you've got the info... you're decision on how to use it :^) Pull-pull is great once you've got a handle on how to install it correctly. It's probably the lightest control setup done properly, but I use direct pushrod using CF tubes myself quite a bit too.
