RE: What Fuel tubing to use inside gas tank
something else.... All the tanks I have had, the line inside going to the clunk is much thinner than regular fuel tubing, and a Lot more flexible. If you use regular tubing, it might be too stiff to hang down to the bottom of the tank when its horizontal. Try and find the thinnest (thin walls not inner diameter) tubing available and it should work better.
