The clunk in the tank tank does not fall down and follow the fuel, it is normal fuel tubing but it must be too stiff
If it is too stiff then it isn't normal fuel tubing. What specific tubing are you using?
Just out of curiosity, how far inside the tank does the brass tubing on you clunk line go? It should only extend into the tank (past the stopper) about a half an inch or so.
