Super Tigre G90 won't idle.
Bax,
I read your sticky on how to adjust ST engine. I have done all that but the engine won't idle.It is a G90 and runs just fine except when I throttle back the engine dies abruptly when it approaches idle speed. It acts like the carb barrel has been suddenly closed although there is still about an 1/8" opening in the throat.
Any suggestions?
Regards,
doubledee
I have also noticed when I try to adjust the low speed needle the throttle assy moves laterally slightly causing the engine to die abruptly.
