Thanks again guys!
Charles I just used a syringe (pulled out the thin metal part that pierces the skin and what is left is about a 1mm hole) then filled it with something called Vinyvil (I've been living in Italy this last year and Vinyvil is their equivalent of Elmers glue). Then I put on the headphones with some fast music and get to work. When you make a mistake you just it away with your finger. Easy peasy. Time consuming, but satisfying.
-stef
