RE: Trainer Knife Edge
after seeing a plane with sfg's (side force generaters)in the crash and rebuild forum, these would add to the lateral area of the fuselage around the wing mounting area and would help with knife edge but you would have to remove the dihedral from the wing.and since this is a high wing plane there probably should be more sfg area below the wing than above it.
