Help me cut ailerons from foam wing
So in the example of the three inch aileron, the aileron will not be 3" it will be somewhat less? Or do you take it all out of the wing? Is there a standard, or just what works? Also, because of the curvature of the wing, will the aileron then be a little thinner at the joint than the wing before it because of the loss of the 1/2" of material?
