RCU Forums - View Single Post - Evolution 58GX2 ign. LED flashing
Old 08-19-2007 | 03:29 AM
pe reivers
Default RE: Evolution 58GX2 ign. LED flashing
look at the sketches, and choose your cooling system. Then you will see that a lot of air can circulate inside your cowl, but it is not set to work on the required cooling business because the air is not forced to go through the engine cooling fins.
Powerful engines need a powerful cooling system. Lack of proper cooling makes itself noticed especially in upline verticals and hoovering.
ID:	744948   Click image for larger version
ID:	744949   Click image for larger version
ID:	744950   Click image for larger version
ID:	744951   Click image for larger version
ID:	744952   Click image for larger version
