RCU Forums - View Single Post - large engine starters
Old 03-18-2003 | 11:06 PM
Whirley Bird
Default Re: large engine starters
Originally posted by buchtes
which is the best - or strongest- 12 V starter to crank a Moki 1.8 or OS 1.6 .
My friend has a cheap Hobbico 12 volt starter thats rated for engines under 1 cu IN.
But he seems to do OK starting the big engines 1.6 and up.All he does is make sure the piston is at the bottom of the stroke.
He also only has a 5 amp battery @ 12 volts.
Just my input.
