RCU Forums - View Single Post - Need Tips On Cleaning out the vx 18 size engine
Old 08-19-2007 | 05:12 PM
ehroof
Default RE: Need Tips On Cleaning out the vx 18 size engine
if you sucked in dirt your engine is probably blown already, basically you take the head off, the backplate you take the conrod off the crankshaft and pull that out and flush it with some wd40 to clean it out, when done, oil the bearings and parts with after run and put it back together, its pretty simple, if you find the inside of the engine dirty, its time for a piston and sleeve rebuild.
