Thanks for the Info
thanks for the info. I was also thinking about running dual standard servos on all of th control sufaces. I don't want the control surfaces to be under powered. I relize that it could cause major problems later on. Do you think that running dual servos on the rudder and the elevator would be a cure to the problem?
