Spektrum / Using one receiver in several planes / binding?
Hi.
I recently purchased a new plane. I have a Spektrum receiver in another plane and would like to use the same receiver in my new plane.
Can I do this while keeping my first plane's setting in the TX? For example, the first plane is set up as "Plane #1" in the TX memory. So, can I select "Plane #2" in the memory and bind it to the receiver?
Then, if I want to go back to the original plane, I would simply need to bind the receiver again using the "Plane #1" memory in the TX?
Does this make sense?
