RE: Prop Nuts - Anything special?
Also, 5/16-24 is a less common thread, and may not be available at your hardware store. 5/16-18 is the common thread.
I highly recommend the Dubro prop nuts. They work well with electric starters, last forever, are easy to install just using the shaft of a screwdriver, and you can avoid all the headaches that go along with spinners.
