RCU Forums - View Single Post - Uproar 60 Balance
Old 03-16-2003 | 03:42 PM
BigBird1
Default Uproar 60 Balance
Originally posted by water_born
BigBird1,
To put the battery in the tail of the Uproar60, did you have to access through the side of the fuse? I tried to push it back from the access hatch, but it won't fit past the trailing edge of the wing.
No, the access was in the bottom of the fuse...with a compartment built and a hatch cover...
Also had to extend the battery lead...
As like you found this out after plane was built...
