Super loop
I was wondering if anyone has tried this, or even if its possible. First, I need to make sure what i know is right. Flaperons are when ailerons drop down, and elevator is mixed it to go down, so the added lift from the ailerons is balanced in the back. First, is this right?
If this is correct, what would happen if you used up elevator. So the ailerons raise from the added lift and the elevator drops. Would this cause a really tight loop? I would expect if you programed the flaperons to drop to almost full throw and same with the elevator, it would cause a really tight loop. Has anyone tried? Im getting a foamie, and im deciding on one or two aileron servos. If this is possible, I might just get two servos for this super loop.
So, has anyone done it, and is it possible? THanks
