RCU Forums - View Single Post - Super loop
Thread: Super loop
Old 08-21-2007 | 02:58 PM
acarter's Avatar
acarter
Default RE: Super loop
ORIGINAL: Shortymet55
If this is correct, what would happen if you used up elevator. So the ailerons raise from the added lift and the elevator drops. Would this cause a really tight loop? I would expect if you programed the flaperons to drop to almost full throw and same with the elevator, it would cause a really tight loop. Has anyone tried? Im getting a foamie, and im deciding on one or two aileron servos. If this is possible, I might just get two servos for this super loop.
So, has anyone done it, and is it possible? THanks
What you are discribing here is elevons, which is when the ailerons drop and the elevator goes up, which does make for a really tigh loop, but as stated above, some planes will not handle this kind of stress.
Good luck!
