RCU Forums - View Single Post - Starter box spin direction?
Old 08-21-2007 | 05:13 PM
snowbl!nd's Avatar
snowbl!nd
Default RE: Starter box spin direction?
To work out if it's turning the right way mount your car/buggy/truggy on the box and engage the starter motor (you don't need the starter to make contact with the flywheel) it should be easy enough to figure out which way it needs to turn to spin the flywheel clockwise (when viewed from crankcase).
If it's not spinning the correct way just reverse the polarity to the motor.
