RCU Forums - View Single Post - zenoha g38 power issues
Old 08-21-2007 | 08:56 PM
Wpgtrucker
Default zenoha g38 power issues
HI
I have a problem you guys might be able to help with!!!!! I have Zenoha G38 in a 1/3 G.P. Pitts Special it starts on runs great with the cowl off the plane and max's out at 7600 rpm with a 18x8 prop and pulls the plane nicely through the air. But when i install the cowl I loose about 500 rpm and it has a tendency to want to die when the plane hit take off speed. this is what i have donne so far
I have opened the cowl up right in from of the carb wich made it it better during take off ( it dosent want to die on take off any more) But still not getting top end power
I tryed a valosity stack and it has made no diffrence
i have baffled the entrance to the cowle and it has not fixed it iether
some has mentioned to me it might be a presure problem in the cowl???????? i dont know how to address that if that is the case i have about 4 time the exit of air as in take
any ideas would be helpfull
