RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-21-2007 | 11:45 PM
  #1713
shaunmichaeljohnson's Avatar
shaunmichaeljohnson
Default RE: gas fuel with glo plug no ignition
from what i belive,
nitro decreases the flash point of the fuel and allows it to ignite at a lower tempreture.
in most cases this means that it will advance the thermo ignition timbing and give more power up to a certain degree.
to achive this you need to let the rpm's accel to get this "bonus power" otherwise you'll get knocking.
i learnt somthing too
i have been running 2 part-25:1 gas/oil ratio and 1 part-10/10 nitro.
so you mean i can use straight gas and just the lube in the nitro is enough?
shaun
