RE: Substitute for Ether
Thank you very much for your fast reply, Andy..
Im from Brazil, south america, and here in winter don´t go lower than 12 celsius degrees, and in summer usually beats more than 30 celsius degrees.. Maybe, here will be more easier to start without ether, no? Or is a lot of hotting required to first start without ether?
And after hot, you take off.. then, when you need turn on the engine again, will be easy to start without ether? And about diesel cetane boosters, does it work or not?
What is your suggestion of diesel fuel mix to me, that want begin without Ether? Can i have some of other type of starting fluid that don´t have ether inside?
Did you try thinner?
Cheers and thank you again! And sorry if some of my doubts are in past pages.. [&o]
Matheus
