RCU Forums - View Single Post - Autorotation for Electrics
Old 08-22-2007 | 03:42 PM
onad's Avatar
onad
Default RE: Autorotation for Electrics
Yah, that is what I thought. Tx, Onad
ORIGINAL: mrasmm
you'll need to upgrade your Tx is basically the answer in short =)
If you go with futaba or hitec you can use the stock receiver. You might also check ebay for a used Tx, they go for really cheap there.
True! Very True!! [sm=spinnyeyes.gif]
ORIGINAL: Motions
You won't be auto'ing a CP Pro anyway so don't worry about it. If a CP hits the ground in less than 5 pieces, consider it a successful auto.
