RCU Forums - View Single Post - SERVO MOUNTING
Old 08-22-2007 | 09:33 PM
Oldbob
Default RE: SERVO MOUNTING
Combatpigg, Do not, do not, do not use CA as a base for Silicone adhesive. This combination has always come loose for me. For some reason I can not get Silicone to stick to CA. What works really good is a thin film of Epoxy. 5, 15, 30 minute. After it cures wipe the Epoxy surface with alcohol to remove any oil film that may form. Now apply the Silicone, about 1/8 inch thick, let cure over night, and you are good to go. You will have to use a razor blade to remove the servo.
Oldbob
