RE: Flying time on a receiver battery.
I would say three 15 minute flights. or however many shorter duration to make that up. Be warned that it can vary greatly if you have tight/binding control linkages or fly with a forced servo. That drains a battery much faster.
A little ESV (expanded scale voltmeter) that measures with a load on the circuit can save a model if you use it before each flight.
