RCU Forums - View Single Post - engine break in help
Old 08-23-2007 | 09:04 AM
ehroof
Default RE: engine break in help
keep running tanks thru it and lean a little each time, you usually need about 10 tanks for an engine to wake up, also make sure that the piston is on the bottom of the stroke (engine) when you let it cool between tanks, you should have the engine running at 200 but not over 230 during the first 10 tanks.
