RE: Twist 3D 150 ARF
I'm flying the 150 with a Saito 150 on it. The only issue I have discovered is that I need to use a prop no larger than 17" for ground clearance. Even a 17X6 catches a fair bit of grass at our field. I had originally flown it with an OS 1.20AX. I like the Saito better, but I'm thinking of going back to the OS.
