RCU Forums - View Single Post - Twist 3D 150 ARF
Old 08-23-2007 | 01:50 PM
NCIS
Default RE: Twist 3D 150 ARF
Ground Clearence,
I'm running an APC 18x6W on my Saito 150 but haven't been able to fly mine yet. The weather has been bad. Our field is maintained by the township where the field is and the grass is usually only about 1" tall. I really like the looks of the wheel pants or I would just use the same gear and run larger tires on it. I'm going to check it out and if I see the prop clearence is an issue that is unbearable I'll have to make a change. I think I have about 1 3/4" of clearence.
Thanks for the heads up,
Gibbs
